flyingcircus Opublikowano 17 Kwietnia 2019 Udostępnij Opublikowano 17 Kwietnia 2019 SONY WM-3Walkman Cassette Player (1981-82) Jako ze nie znalazłem żadnej specyfikacji do tego modelu (albo tez nie szukałem zbyt wnikliwie wklejam opis z walkmancentral.com proszę sobie przetłumaczyc "WM-3 was the new number for the TPS-L2. The new numbering fitted nicely into the range with the WM-2 and WM-1, and even though technology had advanced greatly in the short time since the original TPS-L2 had appeared, very few changes were made. The changes are, however, worth noting. The play key was now labelled “play” instead of “listen”. The talk-line button, now silver and matching the tape transport keys in finish, latched down (previously it had had a momentary action). The DC input socket was changed to a smaller size so that the same AC adaptor and battery holder that was supplied with the WM-2 could be used. The tone switch was now re-labelled as a tape-type selector for normal and chrome/metal tapes. Because of this, a logo for metal tape was printed clearly on the front of the machine. The carrying case had been restyled and now allowed the cassette to be more visible and more easily changed. Finally, the case (and the carrying case) became black instead of blue. None of these changes altered the performance of the machine in any real way, and no noticeable changes were made to the mechanical or electronic parts. The WM-3 was quite large compared to the WM-2 (though it was smaller than the WM-1) but was slightly more expensive, it was sold as a high-quality alternative. For some markets, a WM-3 “Excellent” was offered, which can be recognised by its gold finish" Na koniec moj egzemplarz. 4 Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
Admin sherlock Opublikowano 17 Kwietnia 2019 Admin Udostępnij Opublikowano 17 Kwietnia 2019 Maszynka jak widać porządnie wykonana. Fajne cacko. Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
audiotone Opublikowano 17 Kwietnia 2019 Udostępnij Opublikowano 17 Kwietnia 2019 Ciekawa maszyna i kolor takli chyba inny... on jest złotawy? Tzn. szampański? Odnośnik do komentarza Udostępnij na innych stronach Więcej opcji udostępniania...
