Admin sherlock Opublikowano 20 Czerwca 2019 Admin Opublikowano 20 Czerwca 2019 List by: Forum-member (russian forum): 3dnowhttp://forum.vegalab.ru/ I offer you a list of some specialized ICs Dolby NR, with available Datasheet's. 1A) All single-channel IC Dolby-B, issued before 1980. Signetics topology in the housing DIP16, are 100% compatible (pin-to-pin & Dolby level). Here they are: CR713B.pdf , LM1011, LM1101AN, LM1111, LM1112.pdf , NE / SE545B, NE645B / NE646B, NE645N, NE646N.pdf , NE648N, NE650N, RH-IX0431AGZZ. 1b) Single-channel IC Dolby-B in the case DIP16, compatible only with each other: LA2730 & M A7300PC.pdf . 1C) Single-channel IC Dolby-B in the case DIP16, compatible only with each other: PA4005 & µPC1180C. 1D) Single-channel IC Dolby-B in the case DIP16, incompatible with previous, and each other : CX174-1 / -2 (DIP16 / DIL16), TA7629P, µPC1210C. 1E) Separately, it may be noted IC NR ANRS AN7362N & TAT000332-01 in the housing DIP16, compatible with NR Dolby-B, were used in decks and JVC Gradiente (OEM JVC ). Additions and corrections to top-end decks , preferably documented confirmed, welcome ! Here systematized information on manufacturers, who applied Dolby NR in tape recorders, and other equipment. 95% of the information is taken from service manuals, catalogs of manufacturers, my personal experience and the help of respected members of the forum . And so, I present to you the result of years of "dialogue" with tape decks. Each deck Applied on the types of systems with noise reduction. Also shown in front of each deck technology applied in them or discrete IC Dolby. An asterisk (*) denotes: 1. Column models - sales region. 2. In Applied on types of UWB - some limitations in the application, for example - only channel playback. 3. Column Applied on EC / discrete value - multiplied by the sign of the number. Aiwa / for Japan* AD-3700U / AD-FF7* - B/C - 4*HA11226 AD-3800U / AD-FF8* - B/C - 4*HA11226 AD-6700/ AD-F70* - B - 2*LM1011N AD-6800/ AD-F80* - B - 4*(2SC828*6+2SK30+2SA628) AD-6900/ AD-F90* - B - 4*CR713 AD-6900 MkII - B - 4*CR713 AD-F360/S15/R460/R30 - B/C - 2*HA12058J AD-F660/ AD-FF60* - B/C - 4*HA12038-01/2*CX20027+2*CX20028 AD-F770/ AD-FF70* - B/C - 4*HA12038-01 AD-F780 - B/C - 2*CX20187 AD-F800 - B/C - 2*CX20187 AD-F880 - B/C - 2*CX20187 AD-F910/XK-5000* - B/C - 2*CX20188 AD-F990/ AD-FF90* - B/C - 4*HA12038-01 AD-F1000 - B/C/DBX - AD-M700U/ AD-F66M* - B - 4*CX174 AD-M800U/ AD-F77M* - B - 4*CX174 AD-R650 - B/C - 4*HA12058-01 AD-S40 - B/C - 4*HA12058-01 AD-S950 - B/C/S - 2*CXA1563S+4*CXA1417S AD-WX727 - B/C - HA12155NT AD-WX777 - B/C - HA12155NT AD-WX808 - B/C/DBX - CX20187 AD-WX909 - B/C - 3*HA12088GN AD-WX929 - B/C - HA12155NT-01 AD-WX999 - B/C - XK-005* - B/C - 2*CX20187 XK-007 Excelia - B/C/DBX - 2*CX20188 XK-009 Excelia - B/C/DBX - 2*CX20188 XK-S7000 - B/C/S - 2*CX20188+4*CXA1417S XK-S9000 - B/C/S - 2*CX20188+4*CXA1417S Akai / for Japan* GX-7 - B/C - 4*NE652 GX-9 - B/C - 4*LA2735 GX-32 - B/C - CX20187 GX-67 - B/C - 2*CXA1331 GX-69 - B/C - 2*CXA1331 GX-73 /GX-6 - B/C - 2*HA12090NT GX-75 /GX-Z7100* - B/C - 2*HA12090NT GX-75mkII /GX-Z7100EX* - B/C - 2*CX20187 GX-93 /GX-8 - B/C/DBX - 2*HA12090NT GX-95 /GX-Z9100* - B/C - 2*HA12090NT GX-95mkII /GX-Z9100EX* - B/C - 2*CX20187 GX-F31 - B/C - 2*HA12038 GX-F71 - B/C - 8*LM1111B GX-F80 - B - 4*CR713B GX-F90 - B - 4*CR713B GX-F91 - B/C - 8*LM1111A GX-F95 - B - 4*LM1111A GX-M50 - B - 4*CR713B GX-R70 /GX-R75CX* - B/C/DBX - 2*HA12058 GX-R88 - B/C - 4*HA12058-01 GX-R99 - B/C - 4*HA12058-01 GXC-570D - B - 4*(µ?C1024H+2SK30A+3*VT) GXC-750D - B - 4*CR713B Alpine/Alpage AL-61 - B/C - 2*HA12038-01 AL-65 - B/C - 4*HA12038-01 AL-80 - B/C - 8*LM1111A/NE650N AL-85 - B/C - 4*HA12038-01 AL-90 - B/C - 4*HA12038-01 AL-300 - B - 4*NE645N Arcam Delta 100 - B/C/S - 2*CXA1332+4*CXA1417S ASC AS-2000 - B/C - 4*HA12038 AS-2001 - B/C - 4*HA12038 AS-3000 - B*/Hi-Com - AS-3001 - B/C - 4*HA12038 Bang & Olufsen Beocord 5000-4705 - B* - 2*NE545B Beocord 5000-4715 - B - 2*NE545B Beocord 5500 - B/C - 2*TEA0665 Beocord 6500 mkII - B/C - Beocord 9000 - B/C* - 4*LM1111AN Bic T-3 - B/C - 4*LM1011 Braun (ADS) C-1 Atelier - B - 2*NE646B C-2 Atelier - B/C - 2*HA12038 C-3 Atelier - B/C - 4*NE652+2*NE654 C-4 Atelier - B/C - 2*CX20188 Carver TD-1700 - B/C - 2*CX20187 Denon / for Japan* DN-770R - B/C - 2*HA12170NT DN-780R - B/C - 2*HA12170NT DN-790R - B/C - 2*CXA1332+4*CXA1417S DR-320 / DR-F2* - B - 2*HA11226 DR-F6 - B/C - 8*LM1111BN DR-F7 - B/C - 8*LM1111BN DR-F8 - B/C - 8*LM1111BN DR-M2 - B/C - 4*TEA0652/NE652 DR-M3 - B/C - 4*TEA0652/NE652 DR-M4 - B/C - 4*TEA0652/NE652 DR-M22 - B/C - 4*TEA0652/NE652 DR-M30HX - B/C - 4*TEA0665 DR-M33 - B/C - 4*TEA0651/NE651 DR-M33HX - B/C - 4*TEA0651/NE651 DR-M44 - B/C - 4*TEA0651/NE651 DR-M44HX - B/C - 4*TEA0651/NE651 DRM-700 /A - B/C - 2*CX20187 DRM-740 - B/C - 2*CXA1330S DRM-800 /A - B/C - 2*CX20187 DRS-810 - B/C - 2*CXA1330XS Dual C-830 - B - 2*LM1011N/NE645B C-839 - B - 2*LM1011N/NE645B C-844 - B/C - 8*LM1111BN C-846 - B/C - 4*TEA0665 CC-5050 - B/C - 2*CX20187 Eumig FL-900 - B - 4*LM1011AN FL-1000µP - B*/Hi-Com - TCA/HA11226 FL-1000µP - B - 2*TCA/HA11226 Fisher CR-5120 - B - 4*NE645B CR-W890 - B/C - CX20187 CR-WZ1 - B/C/DBX - CX20187 Grundig CF-5000 - B - 2*µA7300?C CF-5000-2 - B - 2*µA7300?C CF-5500 - B - 4*NE645 CF-5500-2 - B - 4*NE645N CF-7500 - B/C - 4*HA12058 CT-905 Fine Arts - B/C - 2*CX20187 MCF-500-MINI - B - 2*µA7300?C MCF-600-MINI - B*/Hi-Com - 2*µA7300?C Harman Kardon CD-301 - B/C - 2*HA12038-01 CD-391 - B/C - 2*HA12038-01 CD-401 - B/C - 4*HA11226 CD-491 - B/C - 4*HA12038/058-01 HK-400XM - B - 4*LM1011N HK-3500 - B - 2*HA11226 TD-302 - B/C - HA12088NT TD-292 - B/C - 2*HA12058-01 TD-392 - B/C - 4*HA12058-01 TD-470 - B/C/S - 2*CXA1563+CXA1417S*4 TD-4800 - B/C/S - 2*CXA1332+CXA1415*8+CXA1416*4 Hitachi / Lo-D D-707 - B/C - D-707 MkII - B/C - 4*HA12058 (2*TM3506-??????) D-909 - B/C - 4*HA12058 (2*TM3506-??????) D-900 - B - 2*HA11226 D-980/M - B - 2*HA11226 D-1100M - B - 4*TA3003-?????? D-2200M - B/C - Play-4*NE650N(2*TA3011C-??????),Rec-4*NE645N (2*TA3011-??????) / 8*NE646B (4*TA3011-??????) D-3300M - B - 4*TA3003-?????? D-5500M - B - 2*HA11226 D-E99 - B/C - 8*NE646B (4*TA3011-??????) D-M2 mk2 mini - B - 2*TA3003-?????? D-R100 - B/C - CXA1561S ITT Hi-Fi 3020 - B - 2*LM1011AN JVC / Victor for Japan DD-7 - S-ANRS (B) - 4*AN7362N DD-9 - S-ANRS (B)/C - 8*LM1111B DD-99 - B/C - 4*NE650N ? KD-2 - ANRS (B) - 2*(5*VT+TA7066P) KD-65 - S-ANRS (B) - 2*TAT000351-01 KD-85 - S-ANRS (B) - 2*TAT000351-01 KD-A7 - S-ANRS (B) - 2*TAT000351-01 KD-A77 - S-ANRS (B) - 4*TAT000351-01 KD-X3 - B/C - 2*TEA0665 TD-SD1 /TD-V1* - B/C - 2*CXA1331S TD-V66 - B/C - 4*NE652 TD-V562 - B/C - 2*CXA1331S TD-V621 - B/C - 2*HA12088ANT TD-V661 - B/C - 2*CXA1331S TD-V662 - B/C - 2*CXA1331S TD-V711 Elite - B/C - 2*HA12088ANT TD-V721 Elite* - B/C - 2*CX20187 TD-V931 Elite* - B/C - 2*CX20188 TD-V1010 Elite - B/C - 2*CX20187 TD-V1050 Elite - B/C - 2*CXA1331 Kenwood KX-770R - B/C - 2*HA12038 KX-880 - B/C - 2*HA12038 KX-880B - B/C - 2*HA12038 KX-880G - B/C - CX20187 KX-880HX - B/C - CX20188 KX-1030/ KX-1003 - B - 4*NE545B /NE645B KX-1060/ KX-1006 - B - 4*LM1011 KX-1100G - B/C - 2*CX20187 KX-1100HX - B/C - 2*CX20188 KX-2060 - B - 4*LM1011N KX-3060 - B/C - 2*CXA1563S KX-7030 - B/C - 2*HA12170NT KX-9010 - B/C - 2*CX20188 Luxman 5K50 - B - 4*NE645B K-03 - B/C - 2*CX20027+2*CX20028 K-04 - B/C - 4*HA12038-01 K-05 - B/C - 4*HA12038-01 K-12 - B - 4*NE645B K-101 - B/C - 2*HA12038-01 K-109 - B/C - 2*CX20027+2*CX20028 Marantz / for Europe* 5030/B - B - 2*HA11226 CD-330 - B - 2*HA11226 PMD-230 /CP-230* - B - BA1102F PMD-430 /CP-430* - B/C/DBX - 2*HA12048 SD-60 - B/C - 2*CX20187 SD-74 - B/C/DBX - 4*TEA0655 SD-930 - B/C/DBX - 2*NE652+2*NE654 SD-4000 - B - 4*LM1101AN SD-9000 - B - 4*LM1101AN SD-9020 - B - 4*NE646B Mitsubishi / Diatone DT-10 - B - 2*(2SC1648*5+2SK30A+2SA823) DT-35 - B/C - 4*HA11226 NAD 6100 Monitor Series - B/C - CX20188 6140 -B - LM111 6150C -B/C - LM1111BN 3240 - B/C - CX20187 6300 Monitor Series - B/C - 2*CX20188 6340 Monitor Series - B/C - CX20188 Nakamichi / for Japan* 480Z - B/C - 4*UA7300PC 481 - B - 2*µA7300?C 500 Dual Tracer - B - 2*(2SC732*4+2SK30+2SA495) 582Z - B/C - 8*µA7300?C 600 - B - 2*(2SC732*3+2SK30+2SA495*2) 600 II - B - 2*(2SC900*3+2SK30+2SA733*2) 680ZX - B - 4*µA7300?C 682ZX - B/C - 8*µA7300?C 700 Tri-Tracer - B - 4*(2SC732*4+2SK30+2SA495) 700 II - B - 4*(2SC900*4+2SK30+2SA733) 700ZXE - B - 4*µA7300?C 700ZXL - B - 4*µA7300?C 1000 II - B - 4*(2SC900*4+2SK30+2SA733) 1000ZXL - B - 4*µA7300?C 1000ZXL Limited - B - 4*µA7300?C BX-1 - B - 2*µA7300?C BX-2 - B/C - 2*TEA0652+2*TEA0654 BX-100 - B - 2*µA7300?C BX-125 - B/C - 2*TEA0652+2*TEA0654 BX-150 - B/C - 2*TEA0652+2*TEA0654 BX-300/ZX-5* - B/C - 4*NE652 Cassette Deck 1 - B/C - 2*CX20188 Cassette Deck 1.5 - B/C - 2*CX20188 CR-3A/E/CR-3O* - B/C - 2*CX20188 CR-4A/E/CR-4O* - B/C - 2*CX20188 CR-5A/E/CR-5O* - B/C - 4*TEA0652/NE652 CR-7A/E/CR-7O* - B/C - 4*TEA0652/NE652 DR-1 - B/C - 2*CX20188 DR-2 - B/C - 2*CX20188 Dragon - B/C - 4*NE652/>Snr. 30487: extra board with 2*CX20188 LX-5 - B/C - 8*µA7300?C/LA2730 MR-1 (Prof) - B/C - 4*TEA0652 MR-2 (Prof) - B/C - 2*NE652+2*NE654 RX-202 - B/C - 2*NE652+2*NE654 RX-303 - B/C - 2*NE652+2*NE654 RX-505 - B/C - 4*TEA0652 ZX-7 - B/C - 8*µA7300?C/LA2730 ZX-9 - B/C - 8*µA7300?C/LA2730 Neal 302 - B - 2*(Discrete) Onkyo K-611 - B/C - 2*HA12142NT K-622 - B/C - TA-207-Integra - B/C - 2*CX20187 TA-250-Integra - B/C - 2*HA12142NT-01 TA-2048/2350-Integra - B/C - 2*HA12090NT TA-2056/2500-Integra - B/C - 4*HA12058 TA-2058/2360-Integra - B/C - 2*HA12090NT TA-2060 - B - 2*HA11226 TA-2066-Integra - B/C - 4*HA12038-01 TA-2070-Integra - B/C - 4*HA11226 TA-2080 - B - 2*HA11226 TA-2090-Integra - B/C/DBX - 4*HA12058 TA-2350/2048-Integra - B/C - TA-2360/2058-Integra - B/C - 2*HA12090NT TA-2500/2056-Integra - B/C - 4*HA12058 TA-2600 - B/C - 2*CX20187 TA-2700/2550-Integra - B/C - 2*CX20187 TA-2800/2570-Integra - B/C - 2*CX20187 TA-6510-Integra - B/C - 2*HA12142NT-01 TA-6711-Integra - B/C - 2*HA12142NT-01 Phase Linear 7000 Series II - B - 4*PA4005 Philips FC-60 - B/C - 2*CX20187 FC-870 - B/C - 2*CX20187 FC-930 - B/C - CXA1331S FC-950 - B/C - 2*CXA1331S N-2552 - B - 4*NE545B N-5748 - B - 4*NE545B N-5756 - B - 4*NE545B N-5758 - B/DNL - 4*NE545B N-5781 - B - 4*NE545B N-5788 - B - 4*NE545B N-5846 - B/DNL - 4*NE545B Pioneer / for Japan* / for USA** CT-8R / CT-880* - B/C - 4*HA11226 CT-9R / CT-980* - B/C - 4*PA3012-01 CT-41 Elite** / CT-900S - B/C/S - 2*CX20188+CXA1417S*4 CT-91 Elite - B/C - 2*CX20188 CT-91A Elite - B/C - 2*CX20188 CT-93 Elite / T-1000S* - B/C/S - 2*CX20188+CXA1417S*4 CT-95 Elite / T-1100S* - B/C/S - 2*CX20188+CXA1417S*4 CT-777 / T-656* - B/C - 2*CX20188 CT-900S / CT-41 Elite** - B/C/S - 2*CX20188+CXA1417S*4 CT-939 - B/C - 2*CX20188 CT-959 - B/C - 2*CX20188 CT-970* - B - 4*PA4005 CT-970 for Europe - B/C/DBX - 2*AN7370K CT-979 - B/C/S - 2*CX20188+CXA1417S*4 CT-1170W - B/C - HA12088NT CT-2070R - B/C/DBX - 2*AN7370K CT-A1 - B - 4*PA4005 CT-A7 - B/C - 4*HA12058NT-01 CT-A9 - B/C - 4*HA12058NT-01 CT-F950 / CT-920* - B - 4*PA4005 CT-F1000 / CT-1000* - B - 4*(2SC711*4+2SK30+2SA628) CT-F1250 - B - 4*PA4005 CT-S540S / CT-S550S - B/C/S - 2*CXA1563S+CXA1917AS*2 CT-S670D - B/C - 2*CXA1562S CT-S710 - B/C - 2*CX20188 CT-S740S - B/C/S - 2*CXA1563S+CXA1917S*4 CT-S800 - B/C - 2*CX20188 CT-S830S - B/C/S - 2*CXA1330+CXA1417S*4 CT-S910 / T-700S* - B/C - 2*CX20188 CT-S920S/ T-770S* - B/C/S - 2*CX20188+CXA1417S*4 REVOX B-215 - B/C - 4*HA12058J B-710 MkII - B/C - 4*LM1111A/4*HA12038 C-115 (Prof) - B/C - 2*CX20187 H-11 - B/C - 2*CX20187 Rotel RD-1010 - B - 4*LM1011AN RD-2200M - B - 2*LM1011N/NE645B SAE C-101 - B - 4*? Saba CD 355 - B/C - 2*HA12038 Sansui D-550M - B - 2*HA11226 D-570 - B/C - 8*NE645B D-705 - B/C - 2*CX20187 D-970 - B/C - 4*HA12038 D-W10 - B/C - 2*HA12058NT SC-5330 - B - 2*NE545B Sanyo RD-5600 - B - 2*NE545B/LM1011AN Sharp /Optonica RT-3838/H - B - 2*RH-IX0431AGZZ RT-9100H / RT-9* - B - 4*NE645B Sony / for Japan* / for Europe** / for USA*** SRP-CT1/ MU-D100* - B/C - 1*CXA1330S TC-177SD / TC6150SD* - B - 4*(TA7122+2SC632*5) TC-199SD - B - 2*(2SC633*4+2SC631+2SA677) TC-D5M - B - 2*CX174 TC-D5Pro MK II - B - 2*CX174 TC-D6C(WM-D6C) - B/C - 2*CX20068 TC-FX7 - B - 2*CX174 TC-FX77 - B/C - 4*CX174 TC-FX510 - B/C - CX20027+CX20028 TC-FX600 - B/C - 4*CX174 TC-FX707R - B/C - CX20027+CX20028 TC-FX1010 - B*/C* - 4*CX174 TC-K8 - B - 2*(2SC634*4+2SC1345+2SA677) TC-K71 - B - 4*CX174 TC-K75 - B - 4*CX174 TC-K77R - B - 2*CX174 TC-K80 mkII - B - 2*CX174 TC-K81 - B - 4*CX174 TC-K88b - B - 2*CX174 TC-K96R - B - 2*(2SC633*4+2SC1345+2SA844) TC-K333ES - B/C - 2*CX20187 TC-K511S - B/C/S - 2*CXA1331S+4*CXA1417Q TC-K555 - B - 4*CX174-1 TC-K555ES - B/C - 8*CX174 TC-K555ES MK II - B/C - 2*CX20087+CX20088*2 TC-K555ESG* - B/C - 2*CX20188 TC-K555ESX* - B/C - 2*CX20188 TC-K600ES /222ESX* - B/C - 2*CX20187 TC-K666ES - B/C - 2*CX20087+CX20088*2 TC-K700ES /333ESX* - B/C - 2*CX20188 TC-K730ES /333ESR* - B/C - 2*CX20188 TC-K777 - B - 4*CX174-1 TC-K777ES - B/C - 2*CX20087+CX20088*2 TC-K777ES MK II - B/C - 2*CX20188 TC-K815S - B/C/S - 2*CXA1563S+4*CXA1417Q TC-K909ES /222ESJ* - B/C/S - 2*CX20188+CXA1417S*4 TC-K950ES /333ESG* - B/C - 2*CX20188 TC-K970ES /333ESL* - B/C - 2*CX20188 TC-K990ES /333ESA* - B/C - 2*CX20188 TC-KA3ES - B/C/S - 2*CX20188+CXA1417Q*4 TC-KA6ES** - B/C/S - 2*CX20188+CXA1417Q*4 TC-KE600S / TC-KA2ES*** - B/C/S - 2*CXA1563M+CXA1917AM*4 TC-S7 - B/C - 2*CXA1331 Studer A-710 (Prof) - Hi-Com - A-710 (Prof) - B/C - 4*LM1111A/4*HA12038 A-721 (Prof) - B/C - 4*HA12058J Tandberg TCD-330 - B - 4*SE/NE545B TCD-340A - B - 4*SE/NE545B TCD-420A - B - 2*LM1011AN TCD-440A - B - 4*LM1011AN TCD-910 (Prof) - B/C - 4*LM1122+4*LM1123 TCD-911 (Prof) - B*/C* - 2*LM1122+2*LM1123 TCD-3004 - B - 4*LM1011AN TCD-3014A - B/C - 4*LM1122+4*LM1123 Tascam 112R - B/C - 2*CX20187 122 - B - 4*NE645B 122 MK II - B/C - 2*CX20187 122 MK III - B/C - 2*CXA1330S 238 - DBX - Teac A-103/105/106/107 - B - 2*NE545B A-650 - B - 2*(5*VT+2SK30) A-770 - B - 4*LM1011N A-800 - B - 4*NE645B C-1 mk ll - B - 4*(2SC536*4+2SK30+2SA733) C-3RX - B - 4*NE645B C-3X - B - 4*NE645B CX-650R - B - 4*NE545B R-777X - B/C/DBX - 2*TEA0665 R-888X - B/C/DBX - 2*CX20187 R-919X Esoteric - B/C/DBX - 2*CX20187 R-999X - B/C/DBX - 4*TEA0665 R-9000 Esoteric - B/C - 2*CX20188 V-3RX - B/DBX - 2*LM1111CN V-700 - B/C - 4*HA12058 V-800X - B/C/DBX - 4*HA12058 V-850X - B/C/DBX - 2*CX20187 V-870 - B/C - 2*CX20187 V-900X - B/C/DBX - 4*HA12058 V-970X Esoteric - B/C/DBX - 2*CX20187 V-5000 - B/C - 2*CXA1330 V-5010 - B/C - 2*CXA1330 V-6030S - B/C/S - 2*CXA1563S + 4*CXA1417S V-7000 - B/C - 2*CXA1330 V-7010 - B/C - 2*CXA1330 V-8030S - B/C/S - 2*CXA1563S + 4*CXA1417S V-9000 Esoteric - B/C - 2*CX20188 Z-6000 - B/C/DBX - 4*NE652+2*NE654 Z-7000 - B/C/DBX - 4*NE652+2*NE654 Technics RS-AZ7 - B/C - AN7357+AN7374S RS-B85 - B/C/DBX - 4*TEA0665 RS-B100 - B/C/DBX - 4*NE651/NE652 RS-B755 - B/C - 4*TEA0665 RS-B765 - B/C - 4*TEA0665 RS-B905 - B/C/DBX - 4*TEA0665 RS-B965 - B/C/DBX - 2*CX20187 RS-BX601 - B/C - AN7354+AN7374S RS-BX707 - B/C - 2*CXA1331S RS-BX727 - B/C - 2*CXA1331S RS-BX747 - B/C - AN7354+AN7374S RS-BX828 - B/C - 2*CXA1331S RS-M02 mini - B - 2*NE646B RS-M63 - B - 4*NE645B RS-M85 - B - 2*(2SC945*4+2SK30A+2SA564) RS-M88 - B - RS-M95/US - B - 4*(2SC2021*4+2SK30A+2SB641) RS-M245X - B/C/DBX - 2*NE654+2*NE652 RS-M253X - B/C/DBX - 4*NE651/???0651 RS-M255X - B/DBX - 2*NE646N RS-M263 - B - 4*NE646N RS-M270X - B/DBX - 2*NE645B RS-M273 - B - 4*NE646N RS-M275X - B/C/DBX - 4*NE645 RS-M280 - B - 4*NE646B Thorens PC-650M - B - 4*NE645/LM1011 Toshiba / Aurex PC-G90AD - B/Adres - 4*TA7629 PC-X60AD - B/Adres - 2*NE646BN PC-X88AD - B/Adres - 4*TA7629 Uher CR-1600 - B - 2*LM1121 Universum CT-2307A 'Senator' - Hi-Com - CT-2337 'Senator' - Hi-Com - Yamaha K-950 - B/C - 2*NE646B K-1000 - B*/DBX* - 2*µ?C1180C K-1020 - B/C/DBX - 4*TEA0665 K-2000 - B/DBX - 4*µ?C1180C KX-670 - B/C - 2*CXA1330S KX-690 - B/C/S - 2*CXA1563S + 4*CXA1917AS KX-800Ti/U - B/C/DBX - 2*CX20188 KX-930 - B/C - 2*CX20188 KX-1200Ti/U - B/C/DBX - 2*CX20188 KX-W900Ti/U - B/C - 2*CX20187 TC-920 - B - 2*NE545B TC-1000 - B - 2*NE545B ------------------------------------------------------------------------------- NE545 = NTE2001 = ECG2001 (=CR713) LM1011 = NE548 = NE645 = ECG2003 (= LM1111 LM1112 LM1011 NE545 XG1011) NE645(N/B)/646 = EGC2004 ----------- LM1112A/B/C DIL-16: "It is a replacement for the LM1111 , NE645/648 with improved performance figures ------------ Other Dolby circuits, the NE648, NE649 and NE650. ---- NE651/NE652 = 18-pin DIP - Dolby C --- NE654 = 24Pin - Dolby C ---- NE660 = 20pin
Admin sherlock Opublikowano 10 Stycznia 2021 Autor Admin Opublikowano 10 Stycznia 2021 How to calibrate ANY cassette deck with a Dolby Level tape (200 nWb/m). Dolby IC.. .........measure point.........required level ------------------------------------------------------------------------- CXA1330............pins 13,18....... 388 mV (-6 dBu) CXA1331............pins 13,18....... 388 mV (-6 dBu) CXA1332............pins 13,18....... 388 mV (-6 dBu) CXA1417Q CXA1563............pins 11,18.........388 mV (-6 dBu) CX20027............pin 24...............580 mV (-2.5 dBu) CX20028............pin 24...............580 mV (-2.5 dBu) CX20187............pins 21,22.........245 mV (-10 dBu) CX20188............pins 21,22.........245 mV (-10 dBu) CR713B.............pin 3.................580 mV (-2.5 dBu) CX174...............pin 9.................690 mV (-1 dBu)* HA11226 HA12038NT........pin 24...............580 mV (-2.5 dBu) HA12058NT........pin 24...............580 mV (-2.5 dBu) HA12088NT........pins 6,37...........300 mV (-8 dBu) HA12090NT........pin 24...............580 mV (-2.5 dBu) HA12141NT........pin 24...............300 mV (-8 dBu) HA12155NT........pin14,51.............580 mV (-2.5 dBu) HA12170 LA2735 LM1011...............pin 3.................580 mV (-2.5 dBu) LM1111...............pin 3.................580 mV (-2.5 dBu) LM1112...............pin 3.................580 mV (-2.5 dBu) NE545................pin 3.................580 mV (-2.5 dBu) NE645................pin 3.................580 mV (-2.5 dBu) NE646................pin 3.................580 mV (-2.5 dBu) NE648................pin 3.................580 mV (-2.5 dBu) NE650................pin 3.................580 mV (-2.5 dBu) NE651................pin 2 or 8..........387 mV (-6 dBu) NE652................pin 2 or 8..........387 mV (-6 dBu) TEA0651............pin 2 or 8...........387 mV (-6 dBu) TEA0652............pin 2 or 8...........387 mV (-6 dBu) TEA0654............pin 18................387 mV (-6 dBu) uA7300..............pin 14...............100 mV (-18 dBu) * this will work with most models using the CX174 IC
