Sony DTC-690
  • Moderator
SONY DTC-690
Parametry:
Type: digital audio tape deck
Track System: 2-channel stereo
Tape Speed: 4.075, 8.15 mm/s
Recording Time: 240 minutes
Heads: 2000rpm, rotary
D/A Converter: 1-bit
A/D Converter: 1-bit
Sampling Frequency: 48, 44.1, 32kHz
   48 kHz: For analog and digital input signals in a standard mode.
   44.1 kHz: For compact disc and pre-recorded DAT tape.
   32 kHz: For analog input signals in a long-play mode.
Frequency Response: 2Hz to 22kHz
Signal to Noise Ratio: 90dB
Dynamic Range: 90dB
Total Harmonic Distortion: 0.005%
Digital Inputs: coaxial, optical
Digital Outputs: optical
Dimensions: 430 x 110 x 350mm
Weight: 5kg
O ile dobrze pamiętam to ten model może mieć problemy z pękającymi plastykami. Coś więcej to pewnie
napisze bo ma w tej materii większe niż ja doświadczenie.
