Sony PCM-2300
SONY PCM-2300
DANE TECHNICZNE:
Tape    Digital audio tape
Recording head    Rotary head
Recording time    Standard: 120 minutes
Long-play mode: 240 minutes (with DT-120)
Tape speed    Standard: 8.15 mm/s
Long-play mode: 4.075 mm/s
Drum rotation    Standard: 2,000 rpm
Long-play mode: 1,000 rpm
Error correction    Double-Read Solomon code
Track pitch    13.6 µm (20.4 µm)
Sampling frequency    48 kHz, 44.1 kHz, 32 kHz
Modulation system    8-10 Modulation
Transfer rate    2.46 Mbit/sec
Number of channels    2 channels, stereo
D/A conversion (Quantization)    Standard: 16-bit linear
Long-play mode: 12-bit non-linear
Frequency response    Standard: 2-20,000 Hz (±0.5 dB)
Long-play mode: 2-14,500 Hz (±0.5 dB)
Signal-to-noise ratio    Standard: more than 86 dB
Long-play mode: more than 92 dB
Total harmonic distortion    Standard: less than 0.07% (1 kHz)
Long-play mode: less than 0.3% (1 kHz)
Wow and flutter    Below measurable limit (±0.001% W. PEAK)
  • Odpowiedzi 2
  • jan0sik
Kilka fotek środka.
Dużo dobrych elementów. Elna "Durex" ;)
