carlsvin Opublikowano 31 Sierpnia 2021 Opublikowano 31 Sierpnia 2021 Kenwood KX-1030 Picked up a Kenwood KX-1030 off ebay .. Seller had video of what it was doing or not doing and i could see the belt was a goo, so i took a chance... Well its up and running .. Here are the before pics. The knobs were a pain to get off as they were welded on pretty good... I put a few scratches in face plate getting them off... Also the Bias knob was frozen in place and had to use lubricant and plyers to help it loose.... When i figure out how you use the bias setting ill find out if it works... Then Added Deoxit to all switches.. Will be adding more pics after i get it together.. Its working but speed keep going off and not sure if its the pinch roller or something else. But i got alot of goop off roller.. 1 2
Admin sherlock Opublikowano 1 Września 2021 Admin Opublikowano 1 Września 2021 Jeśli chcesz zobaczyć zdjęcie, zaloguj się lub zarejestruj nowe konto is there a chance to take a photo of the entire front? 1
ke_raj Opublikowano 1 Września 2021 Opublikowano 1 Września 2021 Śliczny deck. Lubię takie "srebro"... 1
schematic, parts list / schemat, lista części
