Kenwood model Eleven GX
Tuning range: FM, MW
Power output: 120 watts per channel into 8Ω (stereo)
Frequency response: 5Hz to 100kHz
Total harmonic distortion: 0.03%
Damping factor: 60
Input sensitivity: 1.5mV (mic), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 70dB (mic), 80dB (MM), 110dB (line)
Output: 150mV (line), 120mV (DIN), 1V (Pre out)
Dimensions: 624 x 206 x 460mm
Weight: 20.5kg
Year: 1979
00U0U_f0FUb7KY11Cz_0CI0t2_1200x900 (1).jpg 00707_1ZDGNiDdD8bz_0CI0t2_1200x900 (1).jpg 00505_9WGaLQ18LLNz_0CI0t2_1200x900.jpg 01212_jcwrSsHIeFaz_0CI0t2_1200x900 (1).jpg 20220308_180049.jpg
20220308_180052.jpg 20220308_180039.jpg 20220308_180058.jpg 20220308_214505.jpg
Just picked up this beauty..... Seller thought it needed lots of work.... So i got a good deal..... Just need a few lamps, and a good cleaning.... And yes the timer actually still works, clean unit..  One big heavy receiver....
Pics wouldnt resize,,,, and the topic ended up at the bottom... But oh well , more important things to worry about
