Yamaha MT1X
Yamaha MT1X
Mechanical Descriptions
Tape : standard cassette; CrO2 tape only (EQ: 70µs)
Heads : hard permalloy 4-channel rec/play head
ferrite 4-channel erase head
Tape speed : 4.75 cm/sec
Pitch control : + / - 1 0 %
Wow & flutter : 0.05% WRMS
Fast forward/rewind time : about 100 seconds (C-60 tape)
Motor : DC servo
Inputs & Outputs
INPUT 1—4 input impedance : 10k ohms
rated input level : - 10dB to - 50dB (input fader in specified position)
minimum input level : - 56dB (gain control MAX, input fader MAX)
maximum input level : + 10dB (gain control MIN, headroom margin)
AUX RTN L/R input impedance : 10k ohms
rated input level : -10dB
ST OUT L/R output impedance : 1k ohms
rated impedance load : 10k ohms or over
rated output level : - 10dB (at 50k ohms)
AUX SEND output impedance : 1k ohms
TAPE OUT 1—4 output impedance : 1k ohms
PHONES rated impedance load : 8-40 ohms
maximum output level : 100mW + 100mW
Equalizer Characteristics HIGH : +/- 10dB (10kHz shelving)
LOW : +/- 10dB (100Hz shelving)
Sound Specifications
Total frequency response : 40Hz—12.5kHz, +/- 3dB
Total signal to noise ratio : 85dB (dbx ON, IHF-A)
Total distortion : less than 1% (EIAJ, 315Hz)
Channel separation : better than 55dB (1 kHz)
Erasure ratio : better than 70dB
General
Power supply : supplied AC adaptor (DC 15V), optional PA11 battery pack (“C” x 10)
Power consumption : 14W
Dimensions (WHD) 365 x 65 x 225 mm
IMG_9010.JPG IMG_9032.JPG J_YAMAHA_MT1X_viewfront.JPG J_YAMAHA_MT1X_viewgeneral2.JPG J_YAMAHA_MT1X_viewgeneral3.JPG
Ciekawe czy w obecnym czasie ktoś używa kasetowych multitracków do tworzenia nagrać pod kątem komercyjnym ... .
