Admin sherlock Postat August 14, 2018 Admin Postat August 14, 2018 Onkyo Integra A-9711 Do kompletu z deckiem TA-6711 Trochę na niego czekałem,ale w końcu jest. Kawał wzmaka. Ciężki jak diabli. Dane techniczne: Power output: 80W/8ohms (under 0,06% THD) (both channels driven 20-20kHz) 140W/4ohms (under 1% THD) (both channels driven 1kHz) Dynamic power: 235W/2ohms 160W/4ohms 100W/8ohms Total Harmonic Distortion: 0,06% at rated power 0,06% at 1W output Intermodulation Distortion: 0,06% at rated power Damping Factor: 120 at 8ohms (1kHz) Input sensitivity: 300mV/25kohm (line) 3mV/47kohm (phono MM, US and Canadian model) 0,3mV (phono MC, US and Canadian model) Output: 300mV/15kohm (REC line) Freguency response: 2Hz-50kHz (+0dB,-1dB) S/N ratio: 110dB (line) 84dB (MM, US and Canadian model) 69dB (MC, US and Canadian model) Diemnsion: 435x164x428 Weight: 14,9kg source: stereo-hifi.com 1 1
Postat de sherlock,
katalog Onkyo Integra 1996
Recomandat de sherlock
0 reacții
Mergi la acest postare
Postat de sherlock,
0 reacții
Postat de sherlock,
0 reacții
