flyingcircus Opublikowano 23 Października 2018 Opublikowano 23 Października 2018 Sony TCD-D8 Portable DAT Recorder(1995-2000) Damen Fotografie https://www.flickr.com/photos/damenfotografie/14771084950Specifications * Tape: Digital audio tape * Recording time: Long-play: 240 minutes (with DT-120) * Recording time: Standard: 120 minutes * Sampling Frequency: 48kHz, 44.1kHz, 32kHz * Standard: Fs 48 kHz 20-22,000 Hz (+ or - 1.0dB) * Standard: Fs 44.1 kHz 20-20,000 Hz (+ or - 1.0dB) * Long-play Mode: Fs 32 kHz 20-14.500 Hz (+ or - 1.0dB) * Standard: More than 87 dB * Long-play Mode: More than 87 dB (1 kHz IHF-A, 22kHz LPF, LINE IN) * Standard: Less than 0.008% (1 kHz IHF-A, 22kHz LPF, LINE IN) * Long-play: Less than 0.09% (1 kHz IHF-A, 22kHz LPF, LINE IN) * Wow And Flutter: Below measurable limit (less than + or - 0.001% W.PEAK) * Impedance: 4.7 Kohms * Minimum Input Level: 0.4mV * Rated Input Level: 500 mV * Minimum Input Level: 80 mV * Audio: Stereo minijack * Impedance: 27 ohms * Rated Output: LINE OUT 500 mV * Maximum Output: PHONES 5 mW + 5 mW * Load Impedance: PHONES 32 ohms * Load Impedance: LINE OUT more than 10 Kohms * Digital I/O-REMOTE jack (special jack): Digital input/output, remote control operation and timer-activated operation is possible * Power Requirements: The car battery cord DCC-E160L(not inc.) for use with 12V car battery of DCC-E260HG (not inc.)I * Power Requirements: DC IN 6V jack accepts the Sony AC power adaptor for use on 240v AC, 50 Hz * Power Requirements: DC 6V four LR6 (size AA) batteries * Power Consumption: 1.2W * Dimensions: Approx. 132.6 x 36.7 x 88.2mm (5.25 x 1.5 x 3.5in.)(w/h/d) not incl. projection parts and controls * Mass: Approx. 500g (1lb. 1oz.) incl. batteries "Przenośny" - jedynie pol kilogramowy odtwarzacz DAT 1 4
Admin sherlock Opublikowano 23 Października 2018 Admin Opublikowano 23 Października 2018 Niegdyś marzenie wszystkich tych, którzy chcieli rejestrować koncerty. Jak to maleństwo wypada użytkowo i brzmieniowo?
flyingcircus Opublikowano 23 Października 2018 Autor Opublikowano 23 Października 2018 Nie posiadam mikrofonu niestety, ani nie uzywalem wejscia Line-in aby kiedykolwiek cos na nim nagrac, wiec jak sobie radzi z nagrywaniem to sie nie wypowiem. Do nagran uzywam DTC-ZE700, a ten to tylko taki odtwarzacz ktory umila mi czas tuz przed samym zasnieciem. A jak gra? Jakosc wiadomo cyfrowa, wiec dobrze. Plusem jest jego prawie bezglosna praca, przy odtwarzaniu oczywiscie.
